[postgis-devel] [PostGIS] #1885: Missing field from tabblock table in tiger2010 census_loader.sql
PostGIS trac at osgeo.org
Thu Nov 29 05:55:28 PST 2012
  Reporter:  bpanulla        |       Owner:  robe
      Type:  defect          |      Status:  closed
  Priority:  medium          |   Milestone:  PostGIS 2.0.2
 Component:  tiger geocoder  |     Version:  2.0.x
Resolution:  fixed           |    Keywords:  history
Comment(by robe):
 Hmm -- I was afraid that all states were not structured the same. That's
 probably why I never ran into the issue loading MA data. Are you using
 r10716.  In theory it should work for all states since I'm simply skipping
 the utyp field if it exists.  Though I haven't tried it with New Hampshire
 for example.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1885#comment:8>
