[postgis-devel] [PostGIS] #2120: shp2pgsql mishandles geometry column
trac at osgeo.org
Thu Nov 29 20:46:47 PST 2012
Reporter: arencambre | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Resolution: invalid | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => invalid
Comment:
There is nothing wrong here. The issue is with your data file.
If you look at the dbf file you've got, you'll see that it indeed does
have a column called the_geom and it infact does have text that looks like
the wkt output of a geometry.
The geometry data is always kept in the .shp file and never has a name.
shp2pgsql when the -g is not spec ified defaults to calling it geom.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2120#comment:2>
