[postgis-devel] [PostGIS] #2025: side location conflict at topogeo_AddLineString() of separate edges
trac at osgeo.org
Tue Oct 2 09:18:05 PDT 2012
Reporter: wimned | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.1.0
Component: topology | Version: trunk
Keywords: |
Comment(by strk):
The problem must not occur. But the testing for new faces is currently
built-in the standard ST_AddEdgeModFace / ST_AddEdgeNewFaces, the first of
which is used by TopoGeo_addLinestring.
Checking later might indeed be faster, but currently there's no function
to "build" a topology from edges already inserted. Well, there was an
attempt (topology.polygonize) but I think it doesn't set the proper edge
linking and isn't even necessarely faster.
Anyway please keep performance considerations away from this ticket.
I'm happy to discuss about that but this ticket is for a confirmed bug.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2025#comment:6>
