[postgis-devel] [PostGIS] #2024: raster: ST_Union is buggy
PostGIS trac at osgeo.org
Wed Oct 3 20:54:17 PDT 2012
  Reporter:  robe     |       Owner:  dustymugs
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.1.0
 Component:  raster   |     Version:  trunk
Resolution:  fixed    |    Keywords:
Comment(by robe):
 Ah I see you did fix the crasher and it now unions everything.  GREAT.  I
 think we lost some speed somewhere or could be just fickleness of my
 computer.  I'm still not seeing muc of a differrence between my clipped on
 unclipped.  I'll test a bit more later do another 2.0/2.1 compare. could
 also be that I did upgrade from 2.0.1 to 2.1.0SVN (which seemed to work
 this time around -- maybe you fixed that too), instead of doing a clean
 install.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2024#comment:18>
