[postgis-devel] [PostGIS] #1659: [raster] ST_Union raster out of memory then kicks the bucket on windows 64bit
trac at osgeo.org
Thu Oct 4 02:12:50 PDT 2012
64bit
Reporter: robe | Owner: pracine
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.0
Component: raster | Version: trunk
Resolution: fixed | Keywords: mingw windows 64bit, 32bit
Changes (by robe):
* status: new => closed
* resolution: => fixed
* milestone: PostGIS 2.0.2 => PostGIS 2.1.0
Comment:
This query doesn't crash anymore:
SELECT ST_AsEWKT(ST_ConvexHull(ST_Union(rast1.rast, 1))) FROM (
(SELECT
ST_SetSRID(ST_SetValue(ST_AddBand(ST_MakeEmptyRaster( 100, 100, (i-1)*100,
(i-1)*100, 0.0005, -0.0005, 0*i, 0*i), '16BSI'), i, (i+1),-6000),4326) As
rast FROM generate_series(1,10) As i) ) As rast1 LIMIT 3;
It just gives an error:
ERROR: rt_raster_new: Dimensions requested exceed the maximum (65535 x
65535) permitted for a raster
Which seems fair enough to me. So I'm closing this out.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1659#comment:14>
