[postgis-devel] [PostGIS] #2024: raster: ST_Union is buggy
trac at osgeo.org
Thu Oct 4 21:16:58 PDT 2012
Reporter: robe | Owner: dustymugs
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.1.0
Component: raster | Version: trunk
Resolution: fixed | Keywords:
Comment(by robe):
FWIW: I really got to rethink my tile sizes. It seems we are more
sensitive to number of rows that need to be traversed than we are to
number of pixels that need to be traversed. So I think the memory copy
between the C and PostgreSQL layer is still eating up most of our time.
My 1000x1000 does so much better:
{{{ -- both of these should traverse the same number of pixels
-- 16,958 ms (1 band) 5 tiles clipping (1000x1000 tile sizes)
SELECT ST_Union(rast,1) , count(*)
FROM (SELECT ST_Clip(rast,geom) As rast
FROM test_1000_1000
CROSS JOIN ST_Buffer(ST_GeomFromText('POINT(231237.436173996
887025.024778253)',26986)
,200, 'quad_segs=2') As geom
WHERE ST_Intersects(rast, geom ) ) As foo;
-- 51,714ms (1 band), 152 tiles clipping (100x100 tile sizes)
SELECT ST_Union(rast,1) ,count(*)
FROM test_100_100
-- more interestingly, clipping makes things worse in 2.1.0 case even
though it
-- should in theory reduce the number of pixels that need to be traversed
-- here is the same run without clipping
-- 14,196 ms (1 band) 5 tiles no clipping
FROM (SELECT rast
FROM test_1000_1000
-- 39,374 ms (1 band), 152 tiles no clipping
FROM (SELECT rast
FROM test_100_100
I'm beginning to think that the reason 2.0.1 seemed to improve with
clipping while 2.1 doesn't is simply because in 2.0.1 the clipping time
was dwarfed significantly by the union (copy pain), so the benefit it gave
to union providing smaller tiles much outweighed the additional
processing.
In 2.1.0 this is not the case -- clipping speed and union speed are more
in par so the extra cycles (e.g. 5 or 152 really adds weight since union
has much less of issue traversing)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2024#comment:23>
