[postgis-devel] [PostGIS] #2029: PostgreSQL geometric to PostGIS type casts missing in extension upgrade script (was: PostgreSQL geometric to PostGIS type casts missing in upgrade script)
trac at osgeo.org
Fri Oct 5 05:28:00 PDT 2012
script
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Changes (by robe):
* owner: strk => robe
Comment:
I was wrong this is only an extension issue because I'm explicitly
removing create type cast etc. statements on the postgis side. Forget why
I'm doing that. The 20_21 script does have the casts as it should and the
21_minor I don't think does which is also correct.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2029#comment:1>
