[postgis-devel] [PostGIS] #2024: raster: ST_Union is buggy
trac at osgeo.org
Fri Oct 5 08:57:02 PDT 2012
Reporter: robe | Owner: dustymugs
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.1.0
Component: raster | Version: trunk
Resolution: fixed | Keywords:
Comment(by dustymugs):
For each part...
1. Mostly correct. What isn't correct is that you're not just copying
your old working raster to your new working raster. The new working
raster will more than likely have a different extent. A two pass
aggregate would be nice to have but I'm not expecting it from PostgreSQL.
2. You could do a line by line memcpy of the intersecting parts from the
old working raster to the new working raster but I don't know how much
time that would save. The MEAN uniontype is the most entertaining of the
union types as it requires two parallel actions, a COUNT and a separate
SUM.
Due to the size of raster tiles, there is no way to use the same method
used for ST_Union(geometry). There, the geometries are collected into an
array and then processed at the end with the final aggregate function.
This means that all the geometries are stored in memory to the end. If we
tried that with rasters, you'll probably run out of memory before getting
to the end.
Realistically, we should only be expecting the following:
1. Is the ST_Union in 2.1 faster than 2.0?
2. Is the output from ST_Union in 2.1 correct?
Exploring places to optimize ST_Union would be great... but there are
other problems to resolve for 2.1.0. Maybe 2.1.1.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2024#comment:25>
