[postgis-devel] linkage against libpq.so (Sandro Santilli)
Sandro Santilli
strk at keybit.net
Fri Oct 5 10:00:13 PDT 2012
On Fri, Oct 05, 2012 at 09:48:42AM -0700, Jeff Janes wrote:
> (Sandro Santilli wrote:)
> > On Thu, Oct 04, 2012 at 07:42:42PM -0700, Jeff Janes wrote:
> >> ticket: http://trac.osgeo.org/postgis/ticket/1830
> >> What I don't understand is why it is linking against an ancient libpq
> >> in the first place. There is a perfectly modern libpq on my system,
> >> and it is located right where pg_config says it is. So why isn't that
> >> one getting preferentially used? postgis seems to be using pg_config
> >> to pick up other configuration settings, just not this one.
> >> I poked around in the Makefiles, but I can't figure it out.
> > Are you saying that PGSQL_FE_LDFLAGS in loader/Makefile is wrong ?
> I think that it is set properly:
> PGSQL_FE_LDFLAGS=-L/usr/local/pgsql/lib -lpq
> lrwxrwxrwx. 1 root root 12 Sep 26 11:06
> /usr/local/pgsql/lib/libpq.so.5 -> libpq.so.5.4
> But for some reason, it does not seem to be taking effect. If I do a
> "make install" (despite make check failing), then run the link
> debugger:
> ldd /usr/local/pgsql/bin/pgsql2shp| fgrep pq
> libpq.so.5 => /usr/lib64/libpq.so.5 (0x0000003660800000)
> lrwxrwxrwx. 1 root root 12 Oct 4 11:18 /usr/lib64/libpq.so.5 -> libpq.so.5.2
> So it is linking against the old version anyway.
In that case it's a system configuration issue, not a PostGIS one.
I think it is a feature that the postgis binaries and scripts adapt
to whatever library the linker provides. It's up to you to instruct
your linker. Try export LD_LIBRARY_PATH=/usr/local/pgsql/lib
> If I remove the rpm which is providing /usr/lib64/libpq.so.5 and then
> redo the config, make, and make install from scratch, it still doesn't
> link the appropriate libpq, now it links nothing at all:
> libpq.so.5 => not found
Did you ldconfig after the removal (I'm hoping in an rpm bug).
Or do you see any -rpath line in the loader's Makefile ?
--strk;
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
