[postgis-devel] pt_br docs
George Silva
georger.silva at gmail.com
Thu Oct 11 13:26:16 PDT 2012
Sandro,
I've updated the translations a bit. I think I made a mistake using the
quotes to delimit the message.
Can you pull from master and try again? My linux box crashed (hard) and I
still need to rebuild it, so I can test the creation of messages without
bothering you.
On Thu, Oct 11, 2012 at 9:23 AM, George Silva <georger.silva at gmail.com>wrote:
> This is weird. Probably some error on the translation?
> Let me check everything again and I'll let you know.
> On Thu, Oct 11, 2012 at 9:21 AM, Sandro Santilli <strk at keybit.net> wrote:
>> Thanks George. I'm trying it but having a problem, unfortunately:
>> po2xml ../../introduction.xml introduction.xml.po > introduction.xml
>> terminate called after throwing an instance of
>> 'antlr::TokenStreamRecognitionException'
>> Aborted (core dumped)
>> You can test yourself too:
>> $ cd doc/po/pt_BR
>> $ make
>> I will need a ticket for this as can't work on it immediately.
>> Thanks!
>> --strk;
>> On Thu, Oct 11, 2012 at 08:49:02AM -0300, George Silva wrote:
>> > I've made a pull request via github.
>> > If you want to merge directly, take a look at my github repository:
>> > https://github.com/george-silva/postgis
>> > I'm translating directly in the svn-trunk branch.
>> > On Wed, Oct 10, 2012 at 7:32 PM, Sandro Santilli <strk at keybit.net>
>> wrote:
>> > > On Wed, Oct 10, 2012 at 03:07:55PM -0300, George Silva wrote:
>> > > > Hello folks,
>> > > > I've managed to translate the entire introduction.xml file.
>> > > > strk, I think we could run a little build test for these documents?
>> > > I think it's all setup to run the tests on commit (and the result
>> > > should actually be directly published)
>> > > > Let's see how this will turn out?
>> > > > Right now it's all in my fork. I'll make a pull request for the
>> official
>> > > > PostGIS repo?
>> > > Yes please, or just push your branch somewhere and report here
>> > > the public repo url and the branch name ( I won't merge pull
>> > > requests with the github interface anyway ).
>> > > --strk;
>> > > http://www.cartodb.com - Map, analyze and build applications with
>> your
>> > > data
>> > > ~~ http://strk.keybit.net
>> > > _______________________________________________
>> > > postgis-devel mailing list
>> > > postgis-devel at postgis.refractions.net
>> > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
>> > George R. C. Silva
>> > Desenvolvimento em GIS
>> > http://geoprocessamento.net
>> > http://blog.geoprocessamento.net
>> http://www.cartodb.com - Map, analyze and build applications with your
>> data
> George R. C. Silva
George R. C. Silva
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20121011/ed9cc762/attachment.html>
