[postgis-devel] pt_br docs
Sandro Santilli
strk at keybit.net
Thu Oct 11 14:46:26 PDT 2012
George: I fixed it myself (was probably easier), rebased
and squashed against svn-trunk. It's in SVN with revision r10406.
You'll probably need to rebase your branch.
I don't know when the product of translation will be available online.
Regina probably knows that
--strk;
On Thu, Oct 11, 2012 at 11:20:00PM +0200, Sandro Santilli wrote:
> Still no luck.
> I took a look and it seems po2xml doesn't like this line (line 39):
> "Britânica - Canadá, especializada em integração de dados e desenvolvimento customizado de software. Nós " "planejamos e suportamos o desenvolvimento do PostGIS para uma ampla de funcionalidades de SIG, incluindo "
> Note the missing newline.
> If you make sure all lines start and end with "
> then it builds fine. Like this:
> Looking forward to next commit :)
> --strk;
> On Thu, Oct 11, 2012 at 05:26:16PM -0300, George Silva wrote:
> > Sandro,
> > I've updated the translations a bit. I think I made a mistake using the
> > quotes to delimit the message.
> > Can you pull from master and try again? My linux box crashed (hard) and I
> > still need to rebuild it, so I can test the creation of messages without
> > bothering you.
> > On Thu, Oct 11, 2012 at 9:23 AM, George Silva <georger.silva at gmail.com>wrote:
> > > This is weird. Probably some error on the translation?
> > > Let me check everything again and I'll let you know.
> > > On Thu, Oct 11, 2012 at 9:21 AM, Sandro Santilli <strk at keybit.net> wrote:
> > >> Thanks George. I'm trying it but having a problem, unfortunately:
> > >> po2xml ../../introduction.xml introduction.xml.po > introduction.xml
> > >> terminate called after throwing an instance of
> > >> 'antlr::TokenStreamRecognitionException'
> > >> Aborted (core dumped)
> > >> You can test yourself too:
> > >> $ cd doc/po/pt_BR
> > >> $ make
> > >> I will need a ticket for this as can't work on it immediately.
> > >> Thanks!
> > >> --strk;
> > >> On Thu, Oct 11, 2012 at 08:49:02AM -0300, George Silva wrote:
> > >> > I've made a pull request via github.
> > >> > If you want to merge directly, take a look at my github repository:
> > >> > https://github.com/george-silva/postgis
> > >> > I'm translating directly in the svn-trunk branch.
> > >> > On Wed, Oct 10, 2012 at 7:32 PM, Sandro Santilli <strk at keybit.net>
> > >> wrote:
> > >> > > On Wed, Oct 10, 2012 at 03:07:55PM -0300, George Silva wrote:
> > >> > > > Hello folks,
> > >> > > > I've managed to translate the entire introduction.xml file.
> > >> > > > strk, I think we could run a little build test for these documents?
> > >> > > I think it's all setup to run the tests on commit (and the result
> > >> > > should actually be directly published)
> > >> > > > Let's see how this will turn out?
> > >> > > > Right now it's all in my fork. I'll make a pull request for the
> > >> official
> > >> > > > PostGIS repo?
> > >> > > Yes please, or just push your branch somewhere and report here
> > >> > > the public repo url and the branch name ( I won't merge pull
> > >> > > requests with the github interface anyway ).
> > >> > > --strk;
> > >> > > http://www.cartodb.com - Map, analyze and build applications with
> > >> your
> > >> > > data
> > >> > > ~~ http://strk.keybit.net
> > >> > > _______________________________________________
> > >> > > postgis-devel mailing list
> > >> > > postgis-devel at postgis.refractions.net
> > >> > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
> > >> > George R. C. Silva
> > >> > Desenvolvimento em GIS
> > >> > http://geoprocessamento.net
> > >> > http://blog.geoprocessamento.net
> > >> http://www.cartodb.com - Map, analyze and build applications with your
> > >> data
> > > George R. C. Silva
> > George R. C. Silva
> http://www.cartodb.com - Map, analyze and build applications with your data
