[postgis-devel] [PostGIS] #2043: test_spheroid_area fails
trac at osgeo.org
Fri Oct 12 06:27:27 PDT 2012
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Debbie and Winnie are similarly unhappy.
Debbie: 64-bit Debian 6
sphere: 12360265021.4
spheroid: 12304814950.1
FAILED
1. cu_geodetic.c:993 -
CU_ASSERT_DOUBLE_EQUAL(a1,89.7127703297,0.0001)
Winnie - Mingw64 32-bit compile
Test: test_lwgeom_area_sphere ...FAILED
1. cu_geodetic.c:1173 -
CU_ASSERT_DOUBLE_EQUAL(area,12360265021.3561,0.01)
Test: test_signum ...passed
Test: test_gbox_from_spherical_coordinates ...passed
Test: test_gserialized_get_gbox_geocentric ...passed
Test: test_clairaut ...passed
Test: test_edge_intersection ...passed
Test: test_edge_distance_to_point ...passed
Test: test_edge_distance_to_edge ...passed
Test: test_lwgeom_distance_sphere ...passed
Test: test_lwgeom_check_geodetic ...passed
Test: test_gserialized_from_lwgeom ...passed
Test: test_spheroid_distance ...passed
Test: test_spheroid_area ...
FAILED
Winnie - 64-bit mingw64 compile
FAILED
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2043#comment:1>
