[postgis-devel] [PostGIS] #2040: lwgeodetic.c:1821:1: error: conflicting types for 'ptarray_area_sphere'
PostGIS trac at osgeo.org
Fri Oct 12 06:39:16 PDT 2012
  Reporter:  robe                   |       Owner:  pramsey
      Type:  defect                 |      Status:  reopened
  Priority:  blocker                |   Milestone:  PostGIS 2.1.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:                         |    Keywords:
Changes (by robe):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 make doc is still failing at compile time.  So though this fixed the make
 check error, still getting the same error on make doc
 I'm rerunning now to confirm
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2040#comment:5>
