[postgis-devel] [PostGIS] #2038: Exception of topogeo_AddLineString() of a line string with a part colinear with an existing one.
trac at osgeo.org
Fri Oct 12 14:54:09 PDT 2012
Reporter: wimned | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.2
Component: topology | Version: trunk
Keywords: |
Comment(by strk):
Since we're at it, the test with one vertex removed (so we have 5 vertices
in total).
Can still reproduce the issue:
SELECT CreateTopology('t2038');
SELECT TopoGeo_addLineString('t2038', 'LINESTRING( 72.91981
20.95009,72.91082 20.95759)');
SELECT TopoGeo_addLineString('t2038', 'LINESTRING(72.9123215921439
20.9563372813038,72.9122229474764 20.9564195766326, 72.9130010661966
20.9562352183313)');
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2038#comment:13>
