[postgis-devel] [PostGIS] #2046: raster: Getting compile errors on postgresql 9.0 build caused by raster
    trac at osgeo.org
    Sat Oct 13 00:16:17 PDT 2012
 Reporter:  robe                   |       Owner:  dustymugs
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:  mingw64                |
Comment(by robe):
 Yap debbie doesn't like it either.  Just set her up with 9.0 and she's
 complaining about the same thing.
 rt_pg.c:14149:134: error: macro "InitFunctionCallInfoData" passed 6
 arguments, but takes just 5
 rt_pg.c: In function ‘RASTER_nMapAlgebra’:
 rt_pg.c:14149: error: ‘InitFunctionCallInfoData’ undeclared (first use in
 this function)
 rt_pg.c:14149: error: (Each undeclared identifier is reported only once
 rt_pg.c:14149: error: for each function it appears in.)
 make[2]: *** [rt_pg.o] Error 1
 make[2]: Leaving directory
 `/var/lib/jenkins/workspace/postgis/branches/2.1/raster/rt_pg'
 make[1]: *** [pglib] Error 2
 make[1]: Leaving directory
 `/var/lib/jenkins/workspace/postgis/branches/2.1/raster'
 make: *** [all] Error 1
 I'm going to add 9.0 as a separate regress name so it's easier to
 distiguish from the regular regress until this issue is fixed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2046#comment:1>
