[postgis-devel] Question about SUSE Geo repository & Postgres/postgis
pcreso at pcreso.com
Mon Oct 15 09:46:17 PDT 2012
Hi Angelos,
What exactly do you mean by "fixing"?
The files list at
http://download.opensuse.org/repositories/Application:/Geo/SLE_11_SP2/
which I figure is the "official Application:Geo" repository you are referring to does not have Postgis v2.0.1, only v1.5.4
At least that I have found.
Cheers,
Brent Wood
--- On Tue, 10/16/12, Angelos Tzotsos <gcpp.kalxas at gmail.com> wrote:
Subject: Re: [postgis-devel] Question about SUSE Geo repository & Postgres/postgis
To: pcreso at pcreso.com
Cc: "PostGIS Development Discussion" <postgis-devel at postgis.refractions.net>, opensuse at dstoecker.de
Date: Tuesday, October 16, 2012, 5:38 AM
In that case, fixing the build for official Application:Geo would be a better solution, since postgis 2.0.1 is already there.
Best,
Angelos
On 10/15/2012 07:28 PM, pcreso at pcreso.com wrote:
> Hi Angelos,
> In theory, yes, I believe Postgres 9.1 is available for SLES11 SP2, so if Postgis 2.0.1 was built against the standard Postgres install that should be fine.
> Appreciated.
> Brent Wood
> --- On Mon, 10/15/12, Angelos Tzotsos <gcpp.kalxas at gmail.com> wrote:
> From: Angelos Tzotsos <gcpp.kalxas at gmail.com>
> To: postgis-devel at postgis.refractions.net
> Cc: opensuse at dstoecker.de
> Date: Monday, October 15, 2012, 7:55 PM
> On 10/15/2012 01:34 AM,
> Hi,
> Is it possible to have the maintainers of this repository build a similar set of Postgres 9.2 & matching Postgis 2.0.1 packages for SLES11 SP2?
> http://download.opensuse.org/repositories/Application:/Geo:/Postgres9PostGIS1/SLE_11_SP1/
> Thanks,
> Brent Wood
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> Hi Brent,
> I think adding postgis2 to this repository would be enough for what
> you need, right?
> Regards,
> Angelos
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athens
> http://users.ntua.gr/tzotsos
> -----Inline Attachment Follows-----
-- Angelos Tzotsos
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20121015/397d27cb/attachment.html>
