[postgis-devel] Fwd: ST_DumpPoints in C
Sandro Santilli strk at keybit.net
Mon Oct 15 11:41:42 PDT 2012
Yes, of course I'm happy for the gift. Thank you Nathan !
About the clone url:
 [strk at gnash:~] git clone https://pd.if.org/git/dumppoints
 Cloning into 'dumppoints'...
 error: server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none while accessing https://pd.if.org/git/dumppoints/info/refs
 fatal: HTTP request failed
 [strk at gnash:~] git clone http://pd.if.org/git/dumppoints
 error: Failed connect to pd.if.org:80; Connection refused while accessing http://pd.if.org/git/dumppoints/info/refs
--strk;
On Mon, Oct 15, 2012 at 11:38:00AM -0700, Paul Ramsey wrote:
> Gift horse, see mouth. I'm happy to have a contribution here, on a
> ticket which has gone un-worked for over two years.
> P.
> On Mon, Oct 15, 2012 at 11:35 AM, Sandro Santilli <strk at keybit.net> wrote:
> > On Mon, Oct 15, 2012 at 06:20:18PM +0000, Nathan Wagner wrote:
> >> On Mon, Oct 15, 2012 at 11:00:29AM -0700, Paul Ramsey wrote:
> >> > It's not mine, it's Nathan's...
> >> > the URL to clone is
> >> > and it's not a patch on PostGIS, it's an extension that depends on PostGIS
> >> I thought it would make testing and use easier if it could be
> >> vetted as an extension before it was merged into PostGIS proper.
> >> I've only tested against Postgres 9.2 and postgis 2.0.  I don't
> >> see any particular reason why it wouldn't work with other versions,
> >> but I may have used some lwgeom functions or struct members that
> >> are particular to 2.0.
> > If you maintained a fork of the git repo currently on github it would
> > have been easier to test, and less integration work for merging in...
> > --strk;
> >  http://www.cartodb.com - Map, analyze and build applications with your data
> >                                        ~~ http://strk.keybit.net
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
