[postgis-devel] API for uploading raster
dustymugs
dustymugs at gmail.com
Tue Oct 16 09:46:54 PDT 2012
Ryagz,
Depending on your application's license, what you may want to look at
will differ. If your application's license is compatible with GPL, you
can always look at how the source for raster2pgsql.exe makes use of the
core raster API.
Or, you can look at PostGIS's doxygen...
http://debbie.postgis.net/documentation/doxygen/2.1/
The file you'd be most interested in is rt_api.h.
-bborie
On 10/16/2012 07:24 AM, ryagz wrote:
> Hi,
> I found that in order to upload raster data we could use raster2psql.py or
> raster2psql.exe. But i would like to implement the upload functionality in
> my application. Looking at gdal i found that gdal provides support only for
> loading from database and not uploading to database. So is there any c or
> c++ api for uploading raster data to postgis database, which could be used
> in my application.
> Thank you.
> Ryagz
> View this message in context: http://postgis.17.n6.nabble.com/API-for-uploading-raster-tp5000518.html
> Sent from the PostGIS - Dev mailing list archive at Nabble.com.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
