[postgis-devel] [PostGIS] #2050: Unable to add constraint: 'extent'. Skipping
trac at osgeo.org
Tue Oct 16 21:13:18 PDT 2012
Reporter: mgm1701 | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: raster | Version: 2.0.x
Keywords: |
When executing:
'''SELECT
AddRasterConstraints('auslig','rast',TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,FALSE,TRUE,TRUE,TRUE,TRUE,TRUE);'''
The following results
NOTICE: Adding SRID constraint
CONTEXT: PL/pgSQL function
addrasterconstraints(name,name,name,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean)
line 53 at RETURN
NOTICE: The constraint "enforce_srid_rast" already exists. To replace
the existing constraint, delete the constraint and call
ApplyRasterConstraints again
CONTEXT: PL/pgSQL function _add_raster_constraint_srid(name,name,name)
line 33 at RETURN
PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 57 at
assignment
PL/pgSQL function
line 53 at RETURN
NOTICE: Adding scale-X constraint
line 53 at RETURN
NOTICE: The constraint "enforce_scalex_rast" already exists. To replace
_add_raster_constraint_scale(name,name,name,character) line 38 at RETURN
PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 60 at
assignment
PL/pgSQL function
line 53 at RETURN
NOTICE: Adding scale-Y constraint
line 53 at RETURN
NOTICE: The constraint "enforce_scaley_rast" already exists. To replace
PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 63 at
assignment
PL/pgSQL function
line 53 at RETURN
NOTICE: Adding blocksize-X constraint
line 53 at RETURN
NOTICE: The constraint "enforce_width_rast" already exists. To replace
_add_raster_constraint_blocksize(name,name,name,text) line 37 at RETURN
PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 71 at
assignment
PL/pgSQL function
line 53 at RETURN
NOTICE: Adding blocksize-Y constraint
line 53 at RETURN
NOTICE: The constraint "enforce_height_rast" already exists. To replace
PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 74 at
assignment
PL/pgSQL function
line 53 at RETURN
NOTICE: Adding alignment constraint
line 53 at RETURN
NOTICE: The constraint "enforce_same_alignment_rast" already exists. To
replace the existing constraint, delete the constraint and call
_add_raster_constraint_alignment(name,name,name) line 29 at RETURN
PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 82 at
assignment
PL/pgSQL function
line 53 at RETURN
NOTICE: Adding number of bands constraint
line 53 at RETURN
NOTICE: The constraint "enforce_num_bands_rast" already exists. To
_add_raster_constraint_num_bands(name,name,name) line 31 at RETURN
PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 88 at
assignment
PL/pgSQL function
line 53 at RETURN
NOTICE: Adding pixel type constraint
line 53 at RETURN
NOTICE: The constraint "enforce_pixel_types_rast" already exists. To
_add_raster_constraint_pixel_types(name,name,name) line 44 at RETURN
PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 91 at
assignment
PL/pgSQL function
line 53 at RETURN
NOTICE: Adding nodata value constraint
line 53 at RETURN
NOTICE: The constraint "enforce_nodata_values_rast" already exists. To
_add_raster_constraint_nodata_values(name,name,name) line 48 at RETURN
PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 94 at
assignment
PL/pgSQL function
line 53 at RETURN
NOTICE: Adding out-of-database constraint
line 53 at RETURN
NOTICE: The constraint "enforce_out_db_rast" already exists. To replace
CONTEXT: PL/pgSQL function _add_raster_constraint_out_db(name,name,name)
line 48 at RETURN
PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 97 at
assignment
PL/pgSQL function
line 53 at RETURN
NOTICE: Adding maximum extent constraint
line 53 at RETURN
NOTICE: Unable to get the extent of a sample raster
CONTEXT: PL/pgSQL function addrasterconstraints(name,name,name,text[])
line 100 at assignment
PL/pgSQL function
line 53 at RETURN
'''WARNING: Unable to add constraint: 'extent'. Skipping'''
line 53 at RETURN
Total query runtime: 505575 ms.
1 row retrieved.
And there no data is in extent.raster_columns
'''SELECT r_table_name, r_raster_column, srid, scale_x, scale_y,
blocksize_x, blocksize_y, same_alignment, regular_blocking, num_bands,
pixel_types, nodata_values, out_db, extent
FROM raster_columns'''
r_table_name r_raster_column srid scale_x scale_y blocksize_x
blocksize_y same_alignment regular_blocking num_bands
pixel_types nodata_values out_db extent
auslig rast 4283 0.0025 -0.0025 2 2 f f 1
{32BF} {-9999} {f}
auslig_sd52 rast 4283 0.0025 -0.0025 2 2 t f
1 {32BF} {-9999} {f}
0103000020BB10000001000000050000000000000000805F4000000000000030C00000000000805F40703D0AD7A33026C00000000000806040703D0AD7A33026C0000000000080604000000000000030C00000000000805F4000000000000030C0
auslig_sd53 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000000000000080604000000000000030C00000000000806040EC51B81E85EB25C0295C8FC2F5286140EC51B81E85EB25C0295C8FC2F528614000000000000030C0000000000080604000000000000030C0
auslig_sd54 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB100000010000000500000048E17A14AEAB614000000000000030C048E17A14AEAB614000000000000022C0EC51B81E852F624000000000000022C0EC51B81E852F624000000000000030C048E17A14AEAB614000000000000030C0
auslig_se51 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000000000000000005E4000000000000034C00000000000005E40D7A3703D0AD72BC00000000000805F40D7A3703D0AD72BC00000000000805F4000000000000034C00000000000005E4000000000000034C0
auslig_se52 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000000000000000805F4000000000000034C00000000000805F4000000000000030C0000000000080604000000000000030C0000000000080604000000000000034C00000000000805F4000000000000034C0
auslig_se53 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000000000000080604000000000000034C0000000000080604000000000000030C0000000000040614000000000000030C0000000000040614000000000000034C0000000000080604000000000000034C0
auslig_se54 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000000000000040614000000000000034C0000000000040614000000000000030C0000000000000624000000000000030C0000000000000624000000000000034C0000000000040614000000000000034C0
auslig_se55 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000000000000000624000000000000034C0000000000000624000000000000030C0EB51B81E858F624000000000000030C0EB51B81E858F624000000000000034C0000000000000624000000000000034C0
auslig_sf50 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000C3F5285C8F5A5C40FFFFFFFFFFFF37C0C3F5285C8F5A5C4014AE47E17A9433C00000000000005E4014AE47E17A9433C00000000000005E40FFFFFFFFFFFF37C0C3F5285C8F5A5C40FFFFFFFFFFFF37C0
auslig_sf51 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000000000000000005E4000000000000038C00000000000005E4000000000000034C00000000000805F4000000000000034C00000000000805F4000000000000038C00000000000005E4000000000000038C0
auslig_sf52 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000000000000000805F4000000000000038C00000000000805F4000000000000034C0000000000080604000000000000034C0000000000080604000000000000038C00000000000805F4000000000000038C0
auslig_sf53 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000000000000080604000000000000038C0000000000080604000000000000034C0000000000040614000000000000034C0000000000040614000000000000038C0000000000080604000000000000038C0
auslig_sf54 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000000000000040614000000000000038C0000000000040614000000000000034C0000000000000624000000000000034C0000000000000624000000000000038C0000000000040614000000000000038C0
auslig_sf55 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000000000000000624000000000000038C0000000000000624000000000000034C0CDCCCCCCCC0C634000000000000034C0CDCCCCCCCC0C634000000000000038C0000000000000624000000000000038C0
auslig_sg50 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000001F85EB51B83A5C400000000000003CC01F85EB51B83A5C4000000000000038C05C8FC2F528005E4000000000000038C05C8FC2F528005E400000000000003CC01F85EB51B83A5C400000000000003CC0
auslig_sg51 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000000000000000005E400000000000003CC00000000000005E4000000000000038C00000000000805F4000000000000038C00000000000805F400000000000003CC00000000000005E400000000000003CC0
auslig_sg52 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000000000000000805F400000000000003CC00000000000805F4000000000000038C0000000000080604000000000000038C000000000008060400000000000003CC00000000000805F400000000000003CC0
auslig_sg53 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB100000010000000500000000000000008060400000000000003CC0000000000080604000000000000038C0000000000040614000000000000038C000000000004061400000000000003CC000000000008060400000000000003CC0
auslig_sg54 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB100000010000000500000000000000004061400000000000003CC0000000000040614000000000000038C0000000000000624000000000000038C000000000000062400000000000003CC000000000004061400000000000003CC0
auslig_sg55 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB100000010000000500000000000000000062400000000000003CC0000000000000624000000000000038C00000000000C0624000000000000038C00000000000C062400000000000003CC000000000000062400000000000003CC0
auslig_sg56 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000000000000000C062400000000000003CC00000000000C0624000000000000038C0999999999931634000000000000038C099999999993163400000000000003CC00000000000C062400000000000003CC0
auslig_sh50 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB100000010000000500000085EB51B81E655C4000000000000040C085EB51B81E655C400000000000003CC00000000000005E400000000000003CC00000000000005E4000000000000040C085EB51B81E655C4000000000000040C0
auslig_sh51 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000000000000000005E4000000000000040C00000000000005E400000000000003CC00000000000805F400000000000003CC00000000000805F4000000000000040C00000000000005E4000000000000040C0
auslig_sh52 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000000000000000805F40B81E85EB512840C00000000000805F40FFFFFFFFFFFF3BC00000000000806040FFFFFFFFFFFF3BC00000000000806040B81E85EB512840C00000000000805F40B81E85EB512840C0
auslig_sh53 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000000000000080604000000000000040C000000000008060400000000000003CC000000000004061400000000000003CC0000000000040614000000000000040C0000000000080604000000000000040C0
auslig_sh54 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000000000000040614000000000000040C000000000004061400000000000003CC000000000000062400000000000003CC0000000000000624000000000000040C0000000000040614000000000000040C0
auslig_sh55 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000000000000000624000000000000040C000000000000062400000000000003CC00000000000C062400000000000003CC00000000000C0624000000000000040C0000000000000624000000000000040C0
auslig_sh56 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000000000000000C0624000000000000040C00000000000C062400000000000003CC014AE47E17A3463400000000000003CC014AE47E17A34634000000000000040C00000000000C0624000000000000040C0
auslig_si50 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB100000010000000500000052B81E85EBBD5C400BD7A3703D9A41C052B81E85EBBD5C4000000000000040C05C8FC2F528005E4000000000000040C05C8FC2F528005E400BD7A3703D9A41C052B81E85EBBD5C400BD7A3703D9A41C0
auslig_si51 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000000000000000005E40AE47E17A143E41C00000000000005E4000000000000040C00000000000805F4000000000000040C00000000000805F40AE47E17A143E41C00000000000005E40AE47E17A143E41C0
auslig_si53 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB100000010000000500000000000000008060400BD7A3703D0A42C0000000000080604000000000000040C0000000000040614000000000000040C000000000004061400BD7A3703D0A42C000000000008060400BD7A3703D0A42C0
auslig_si54 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000000000000040614000000000000042C0000000000040614000000000000040C0000000000000624000000000000040C0000000000000624000000000000042C0000000000040614000000000000042C0
auslig_si55 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000000000000000624000000000000042C0000000000000624000000000000040C0000000000090624000000000000040C0000000000090624000000000000042C0000000000000624000000000000042C0
auslig_si56 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000000000000090624000000000000042C0000000000090624000000000000040C0EB51B81E8513634000000000000040C0EB51B81E8513634000000000000042C0000000000090624000000000000042C0
auslig_sj54 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB1000000100000005000000F6285C8FC26D6140AE47E17A146E43C0F6285C8FC26D614000000000000042C0000000000000624000000000000042C00000000000006240AE47E17A146E43C0F6285C8FC26D6140AE47E17A146E43C0
auslig_sj55 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000000000000000006240A4703D0AD7C343C0000000000000624000000000000042C08FC2F5285CC7624000000000000042C08FC2F5285CC76240A4703D0AD7C343C00000000000006240A4703D0AD7C343C0
auslig_sk55 rast 4283 0.0025 -0.0025 2 2 t f
0103000020BB10000001000000050000005C8FC2F528FA6140D8A3703D0ADF45C05C8FC2F528FA6140EC51B81E85C343C052B81E85EB8F6240EC51B81E85C343C052B81E85EB8F6240D8A3703D0ADF45C05C8FC2F528FA6140D8A3703D0ADF45C0
"POSTGIS="2.0.1 r9979" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0, 6 March
2012" GDAL="GDAL 1.9.1, released 2012/05/15" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER"
I believe it could be a memory problem as postgresql memory usage sky
rockets to 100%.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2050>
