[postgis-devel] [PostGIS] #2050: Unable to add constraint: 'extent'. Skipping
PostGIS trac at osgeo.org
Wed Oct 17 07:15:14 PDT 2012
 Reporter:  mgm1701  |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.2
Component:  raster   |     Version:  2.0.x
 Keywords:           |
Comment(by dustymugs):
 After looking at your sql file, you're using partitions.  So, I'm going to
 assume many inherited tables, each holding many rows.  It that situation,
 you'll more than likely run out of memory.  ST_Collect tries to be fast,
 which means it tries to cache input geometries until the end.  I'll add a
 fallback approach using ST_MemUnion, which does not caching but is orders
 of magnitude slower.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2050#comment:3>
