[postgis-devel] [PostGIS] #2055: Intersection with a result from Intersection fails
PostGIS trac at osgeo.org
Thu Oct 18 03:44:53 PDT 2012
 Reporter:  bscholten     |       Owner:  pramsey
     Type:  defect        |      Status:  new
 Priority:  medium        |   Milestone:  PostGIS 1.5.6
Component:  postgis       |     Version:  1.5.X
 Keywords:  Intersection  |
 Basic problem:
 Following query gives an error:
 SELECT ST_Intersection(ST_Intersection(first_column, second_column),
 third_column) FROM test_bug_situation
 The error returned is:
 NOTICE:  TopologyException: no outgoing dirEdge found at
 184311.56259997687 319320.99999998196
 ERROR:  GEOS Intersection() threw an error!
 ********** Fout **********
 SQL status:XX000
 ST_IsValid and ST_IsSimple both return true for all columns and
 ST_Intersection(first_column, second_column).
 Switching the columns doesn't throw an error:
 ST_Intersection(ST_Intersection(first_column, third_column),
 second_column)
 or
 ST_Intersection(ST_Intersection(third_column, second_column),
 first_column)
 Extra information:
 Postgres version:
 "PostgreSQL 8.4.12, compiled by Visual C++ build 1400, 32-bit"
 Postgis full version:
 "POSTGIS="1.5.5" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.6.1, 21 August 2008"
 LIBXML="2.7.8" USE_STATS"
 Tested on windows platform.
 See accompanying bug_report_XYZ_column_base64 for each geometry encoded in
 base64 Encoded WKB.
 Same test with POSTGIS 1.4.2 on both Windows and Linux has same results.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2055>
