[postgis-devel] [PostGIS] #2056: [raster] ST_SetValue() for point does NOT check SRID
trac at osgeo.org
Thu Oct 18 13:42:02 PDT 2012
Reporter: dustymugs | Owner: dustymugs
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by dustymugs):
WITH foo AS (
SELECT ST_AddBand(ST_MakeEmptyRaster(5, 5, -119, 51, 1, -1, 0, 0,
4326), 1, '8BUI', 1, 0) AS rast
), bar AS (
SELECT ST_Transform('SRID=4326;POINT(-118 50)'::geometry, 26911)
AS geom
SELECT
ST_SetValue(rast, 1, geom, 5)
FROM foo
CROSS JOIN bar;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2056#comment:1>
