[postgis-devel] [PostGIS] #2057: Raster build ignores pg_config info
PostGIS trac at osgeo.org
Fri Oct 19 10:45:56 PDT 2012
 Reporter:  pramsey  |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.2
Component:  raster   |     Version:  2.0.x
 Keywords:           |
 From IRC:
 fullstop: The configure script for 2.0.1 doesn't use the info from
 pg_config for the raster stuff.
 fullstop: It will fail to find -lpq unless it is in, say, /usr/lib
 fullstop: Adding -L/path/to/pgsql/lib in the Makefile works around this,
 but I'm guessing that the configure script is slightly broken.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2057>
