[postgis-devel] [PostGIS] #2062: Performance Drop in	ST_Distance(geog)
    trac at osgeo.org
    Tue Oct 23 13:50:49 PDT 2012
 Reporter:  pramsey  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.2
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Description changed by pramsey:
Old description:
> Versions 2.0+ included a change in the distance code that results in
> repetitive calculation of the geocentric bounds of objects during
> distance calcs. This can cause much longer return times. See #1976,
> comment #7.
New description:
 repetitive calculation of the geocentric bounds of objects during distance
 calcs. This can cause much longer return times. See #1976, comment 7.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2062#comment:1>
