[postgis-devel] [PostGIS] #2063: lwgeodetic_tree vertex crossing case wrong
trac at osgeo.org
Tue Oct 23 14:50:51 PDT 2012
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
The implementation of the point-in-ring code for the spherical tree
depends on vertex crossing tests that assume you can disregard "lower"
vertices and that's not true. The code needs to be reworked to use the new
intersection test from #1976.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2063>
