[postgis-devel] [PostGIS] #2068: [raster] Make out_db column of raster_columns view behave correctly
trac at osgeo.org
Fri Oct 26 05:42:53 PDT 2012
Reporter: dustymugs | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.2
Component: raster | Version: 2.0.x
Keywords: |
Changes (by mloskot):
* cc: mateusz@… (added)
Comment:
Here is my chat on this problem with dustymags last night, copied from
http://irclogs.geoapt.com/postgis/%23postgis.2012-10-26.log
00:17:41 mloskot: dustymugs: here is the story
00:17:50 mloskot: 1. create table with raster column
00:18:03 mloskot: 2. Insert images
00:18:44 mloskot: 3. AddRasterConstraints(..., FALSE, TRUE)
-- means I say FALSE for out_db constraints
00:19:05 dustymugs: ok
00:19:07 mloskot: Does it mean, I require the out_db field
in raster_columns has NULL value?
00:19:48 mloskot: or default value (whatever it is)
00:19:48 dustymugs: let me jog my memory
00:20:36 mloskot: dustymugs: no rush, I'll try to catch you
tomorrow, it's afte 1am for me, so heading off now
00:20:44 dustymugs: OK
00:21:01 dustymugs: looking at my main raster db, the out_db
column is NULL...
00:21:06 mloskot: dustymugs: simply, I have an impression
the constraints could be documented better, but first I have to understand
it well :)
00:21:10 mloskot: right
00:21:23 dustymugs: yeah... I really need to refresh my memory
about this
00:21:32 mloskot: but, if the out_db constraint is set to
TRUE, then we have two options:
00:21:51 dustymugs: probably need to check the tickets related
to this very column
00:21:57 mloskot: a) if it's in-db raster, e.g. 3 bands,
value will be {f,f,f}
00:22:01 dustymugs: I think there is something historical...
00:22:06 mloskot: b) if out-db ratser, then {t,t,t}
00:22:24 dustymugs: your A and B examples are what the ideal
should be
00:22:25 mloskot: so, FALSE means UNKNOWN, thus seems imply
NULL
00:23:09 dustymugs: FALSE in the addrasterconstraint means
that the function does NOT attempt to add the outdb constraint... so, the
out_db column would be NULL
00:23:22 mloskot: ok, that makes sense
00:23:27 dustymugs: BUT!!!!
00:23:30 mloskot: ?
00:23:56 dustymugs: by the looks of my production database, I
DO have the outdb constraint on my raster columns
00:24:05 dustymugs: AND the out_db column is NULL
00:24:23 dustymugs: It should have some {t} or {f}
combinations
00:24:35 mloskot: yup
00:25:03 dustymugs: I'm almost certain there is something
historical reason why I didn't follow through with it
00:25:16 dustymugs: I'll need to dig through emails and the
tickets to see what is up
00:25:38 dustymugs: for 2.1, I will make the behavior
consistent though... heck... new ticket time
00:25:50 mloskot: it's not that important, but in case you'd
have a spare moment to find that, I'd appreciate, no rush though
00:25:52 mloskot: cheers
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2068#comment:2>
