[postgis-devel] [PostGIS] #1869: ST_AsBinary is not unique	(again)
    trac at osgeo.org
    Sun Sep  2 23:51:58 PDT 2012
  Reporter:  nidi     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:
 Component:  postgis  |     Version:  2.0.x
Resolution:  wontfix  |    Keywords:
Changes (by erilem):
 * cc: erilem (added)
Comment:
 Here's a query that works with 1.x and does not work with 2.x:
 SELECT
   anon.lake_id, ST_AsBinary(anon.lake_geom)
 FROM
   (SELECT
      lake.id AS lake_id, ST_AsBinary(lake.geom) AS lake_geom
    FROM
      lake
    WHERE
      lake.geom IS NULL
    UNION
    SELECT
    FROM
      lake
    WHERE
      lake.geom IS NOT NULL
   ) AS anon;
 The error:
 function st_asbinary(bytea) is not unique
 LINE1: SELECT anon.lake_id, ST_AsBinary(anon...
 HINT:  Could not choose a best candidate function. You might need to add
 explicit type casts.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1869#comment:3>
