[postgis-devel] [PostGIS] #1964: Regression in ST_StartPoint()
trac at osgeo.org
Mon Sep 3 14:37:50 PDT 2012
Reporter: pramsey | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Resolution: duplicate | Keywords:
Comment(by robe):
An exception IS BETTER. It too me at least an hour to track down why my
tiger geocoder was working in 1.5 and returning null points for everything
in 2.0. If a simple error was thrown that said "Only works with
linestraings" , that time owuld have been reduced to less than 5 minutes.
If you are going to have a breaking change, break hard not silently. The
only thing worse than an error is the wrong answer you are expecting to be
right.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1964#comment:7>
