[postgis-devel] [PostGIS] #595: [raster] Add a series of ST_SetValues functions
trac at osgeo.org
Tue Sep 4 11:22:14 PDT 2012
Reporter: pracine | Owner: pracine
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: raster | Version: trunk
Keywords: history |
Comment(by pracine):
Why not? I agree that when the pixel size of the second raster is
significantly smaller than the pixel size of the first, the copied value
is not really representative and that the main goal of this function is to
provide a fast way to copy raster to raster (avoiding the complexity of
determining aggregated value for one pixel) and to be used by
ST_MapAlgebra which does not work on unaligned rasters...
Taking the centroid does not change the result when the rasters are
aligned and it make the function more flexible for other use cases. I
would just document the fact that using ST_SetValues with raster of
different pixel size can results in not so representative pixel values.
If you want to threat the pixel as a polygon, use ST_MapAlgebraFct with a
special function converting the shape of the pixel to a polygon,
intersecting with the second raster and offering a series of methods to
select the pixel value: COUNT, DISTINCT_COUNT, COUNT_MOST_FREQUENT,
COUNT_LEAST_FREQUENT, MOST_FREQUENT_VALUE, LEAST_FREQUENT_VALUE, MAXIMUM,
MINIMUM, RANGE, SUM, MEAN, STDDEV, etc... See Objective FV.27 in the
specs.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/595#comment:18>
