[postgis-devel] [PostGIS] #1970: copytopology regress on 9.2rc1 windows 32
trac at osgeo.org
Wed Sep 5 06:04:41 PDT 2012
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: topology | Version: trunk
Keywords: |
Comment(by robe):
strk -- I think this is probably an issue with all 9.2 that log_cnt is not
returning what old versions did. I found this:
http://postgresql.1045698.n5.nabble.com/pgsql-Don-t-select-log-cnt-in-
sequence-regression-tests-td4514085.html
I wonder if we should do the same, change your SELECT * calls well at
least for the
SELECT * from "CITY_data_UP_down".layer_id_seq;
to
SELECT sequence_name, last_value, start_value, increment_by, max_value,
min_value, cache_value, is_cycled, is_called from
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1970#comment:2>
