[postgis-devel] [PostGIS] #1982: Topology not found when installed with EXTENSION
PostGIS trac at osgeo.org
Thu Sep 6 12:53:53 PDT 2012
 Reporter:  strk                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 template_postgis=# create extension postgis;
 CREATE EXTENSION
 template_postgis=# create extension postgis_topology;
 CREATE EXTENSION
 template_postgis=# select postgis_full_version();
  POSTGIS="2.1.0SVN r10237" GEOS="3.4.0dev-CAPI-1.8.0 r3703" PROJ="Rel.
 4.8.0, 6 March 2012" GDAL="GDAL 2.0dev, released 2011/12/29"
 LIBXML="2.7.8" LIBJSON="UNKNOWN" RASTER
 Where's the topology ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1982>
