[postgis-devel] [PostGIS] #1986: Support curved geometry in ST_GeomFromGML
PostGIS trac at osgeo.org
Fri Sep 7 13:09:05 PDT 2012
 Reporter:  pramsey      |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  postgis      |     Version:  trunk
 Keywords:  sql/mm       |
 In general, GML allows representation of curved features from SQL/MM so we
 should be able to consume them.
 For example:
 select st_astext(st_geomfromgml(
     '<gml:Polygon xmlns:gml="http://www.opengis.net/gml/3.2"
     gml:id="HPA.15449990010" srsName="urn:ogc:def:crs:EPSG::2065"
     srsDimension="2">
     <gml:exterior>
     <gml:Ring>
     <gml:curveMember>
     <gml:LineString gml:id="HPA.15449990010.1">
     <gml:posList>711540.35 1070163.61 711523.82 1070166.54 711521.30
 1070164.14 711519.52 1070162.44 711518.57 1070164.62 712154.47
 1070824.94</gml:posList>
     </gml:LineString>
     </gml:curveMember>
     <gml:curveMember>
     <gml:Curve gml:id="HPA.15449990010.2">
     <gml:segments><gml:ArcString>
     <gml:posList>712154.47 1070824.94 712154.98 1070826.04 712154.41
 1070827.22</gml:posList>
     </gml:ArcString>
     </gml:segments>
     </gml:Curve>
     </gml:curveMember>
     <gml:curveMember>
     <gml:LineString gml:id="HPA.15449990010.3">
     <gml:posList>712154.41 1070827.22 712160.31 1070837.07 712160.92
 1070835.36 712207.89 1071007.95</gml:posList>
     </gml:LineString>
     </gml:curveMember>
     <gml:curveMember>
     <gml:Curve
 gml:id="HPA.15449990010.4"><gml:segments><gml:ArcString><gml:posList>712207.89
 1071007.95 712207.48 1071005.59 712208.38
 1071001.28</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember><gml:curveMember><gml:LineString
 gml:id="HPA.15449990010.5"><gml:posList>712208.38 1071001.28 712228.74
 1070949.67 712233.98 1070936.15 712124.93
 1070788.72</gml:posList></gml:LineString></gml:curveMember><gml:curveMember><gml:Curve
 gml:id="HPA.15449990010.6"><gml:segments><gml:ArcString><gml:posList>712124.93
 1070788.72 712124.28 1070785.87 712124.63
 1070783.38</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember><gml:curveMember><gml:LineString
 gml:id="HPA.15449990010.7"><gml:posList>712124.63 1070783.38 712141.04
 1070764.12 712146.60 1070757.01 711540.35
 1070163.61</gml:posList></gml:LineString></gml:curveMember></gml:Ring></gml:exterior>
     <gml:interior>
     <gml:LinearRing>
     <gml:posList>713061.62 1070354.46 713053.59 1070335.12 713049.58
 1070315.92 713049.65 1070298.33 713061.62 1070354.46</gml:posList>
     </gml:LinearRing>
     </gml:interior>
     </gml:Polygon>'));
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1986>
