[postgis-devel] [PostGIS] #1980: Winnie hiccuping on mathml doc html
trac at osgeo.org
Fri Sep 7 13:55:28 PDT 2012
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: buildbots | Version: trunk
Keywords: |
Comment(by robe):
I got debbie strong enough to build the docs and the PDF and to scp them
up to the PostGIS website :)
http://www.postgis.org/download/postgis-2.1.0SVN.pdf
Not too shabby and the mathml works correctly under Debbie probably
because it's locally installed. So this is less critical and I've stopped
the doc build on Winnie and switched the task to Debbie.
Still having issue with getting Debbie to configure with raster support.
Doesn't accept my custom gdal-config passed in. Bborie is looking into
that issue on the Debian VM he is building.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1980#comment:2>
