[postgis-devel] [PostGIS] #1992: Can't compile under mingw64 anymore
PostGIS trac at osgeo.org
Tue Sep 11 18:04:45 PDT 2012
 Reporter:  robe      |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.1.0
Component:  postgis   |     Version:  trunk
 Keywords:            |
 At first I thought it was just winnie having a hiccup, but I'm having the
 same issue on my windows 7 desktop box.
 x86_64-w64-mingw32-gcc -g -O2  -DDLL_EXPORT -DPIC  -Wall -Wmissing-
 prototypes -I
 ../rt_core -I../../liblwgeom
 -I/c/ming64/projects/gdal/rel-1.9.1w64/include -I/c
 /ming64/projects/geos/rel-3.4.0devw64/include  -I/c/ming64/projects/rel-
 libiconv
 -1.13.1w64/include -c raster2pgsql.c
 In file included from ../../liblwgeom/lwgeom_geos.h:20:0,
                  from ../rt_core/rt_api.h:99,
                  from raster2pgsql.h:44,
                  from raster2pgsql.c:29:
 ../../liblwgeom/liblwgeom.h:22:22: fatal error: proj_api.h: No such file
 or dire
 ctory
 compilation terminated.
 make[2]: *** [raster2pgsql.o] Error 1
 make[2]: Leaving directory
 `/c/ming64/projects/postgis/postgis-2.1.0SVN/raster/l
 oader'
 make[1]: *** [rtloader] Error 2
 make[1]: Leaving directory
 `/c/ming64/projects/postgis/postgis-2.1.0SVN/raster'
 make: *** [all] Error 1
 Unfortunately I don't keep more than 10 logs back and I must have had a
 stupid setting that was passing it off as success.
 Seems like its been a couple of days.
 I'm going ot check my regular mingw32 to se if it has the same issue
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1992>
