[postgis-devel] [PostGIS] #1992: Can't compile under mingw64 anymore
PostGIS trac at osgeo.org
Tue Sep 11 18:34:10 PDT 2012
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  critical               |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 Yap that's it.  Reverting the file fixes my issue.  You mind if I revert
 or you want me to try to make the minimal of changes to make it still
 work.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1992#comment:4>
