[postgis-devel] [PostGIS] #1998: Crash of topogeo_AddPolygon() with "ERROR: query string argument of EXECUTE is null"
trac at osgeo.org
Fri Sep 14 03:03:22 PDT 2012
EXECUTE is null"
Reporter: wimned | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: topogeo_AddPolygon |
Complete message:
CONTEXT: PL/pgSQL function "st_modedgesplit" line 106 at EXECUTE
statement
PL/pgSQL function "topogeo_addpoint" line 65 at assignment
PL/pgSQL function "topogeo_addlinestring" line 92 at assignment
SQL statement "SELECT array_cat(edges, array_agg(x)) FROM ( select
topology.TopoGeo_addLinestring(atopology, rec.geom, tol) as x ) as foo"
Version:
POSTGIS="2.1.0SVN r10195" GEOS="3.3.4-CAPI-1.7.3" PROJ="Rel. 4.7.1, 23
September 2009" LIBXML="2.7.8" TOPOLOGY
After pol1 is added, node 2, the begin and end of the loop of pol1 is
removed through ST_ModEdgeHeal().
The code breaks when pol2 is added after this.
Rearranging the geometry of pol1, so the common point of pol0 and pol1 is
the begin/endpoint of the loop of pol1, prevents the crash.
The code:
CREATE OR REPLACE FUNCTION testerror1()
returns void as
declare pol0 geometry;
declare pol1 geometry;
declare pol2 geometry;
declare node_rec RECORD;
begin
raise notice 'version: %', postgis_full_version();
perform CreateTopology('wimpy', 4326, 0.0000001);
CREATE VIEW face_geom AS
select i.face_id, ST_GetFaceGeometry('wimpy', i.face_id) as geom
from wimpy.face as i
where face_id != 0;
pol0 = ST_GeometryFromText(
'POLYGON((76.5282669067383 9.43292331695557,76.5287322998047
9.43261814117432,76.5285415649414 9.43255615234375,76.5282669067383
9.43292331695557))', 4326);
pol1 = ST_GeometryFromText(
'POLYGON((76.5267181396484 9.4406852722168,76.5282669067383
9.43292331695557, 76.5264434814453 9.43406867980957, 76.5267181396484
9.4406852722168))',4326);
pol2 = ST_GeometryFromText(
'POLYGON((76.524 9.437,
76.5267181396484 9.4406852722168,76.5264434814453
9.43406867980957,76.524 9.437))', 4326);
perform topogeo_AddPolygon('wimpy', pol0);
perform topogeo_AddPolygon('wimpy', pol1);
perform cleanse_nodes();
perform topogeo_AddPolygon('wimpy', pol2);
END
LANGUAGE plpgsql;
CREATE OR REPLACE FUNCTION cleanse_nodes()
returns void AS
DECLARE node_rec RECORD;
BEGIN
for node_rec in select node_id from node
loop
perform cleanse_node(node_rec.node_id);
end loop;
END
LANGUAGE plpgsql;
CREATE OR REPLACE FUNCTION cleanse_node(passed_node_id integer)
returns void AS
DECLARE edge_ids integer[];
BEGIN
--raise notice 'check node %', passed_node_id;
select array_agg(abs(t.edge)) into edge_ids
from GetNodeEdges('wimpy', passed_node_id) as t(seq,edge);
if array_length(edge_ids,1) = 2 and edge_ids[1] != edge_ids[2]
then
raise notice 'remove node %', passed_node_id;
perform ST_ModEdgeHeal('wimpy', edge_ids[1], edge_ids[2]);
end if;
END
LANGUAGE plpgsql;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1998>
