[postgis-devel] [PostGIS] #2000: allow the meter offset right/left to be overriden at geocode function level
trac at osgeo.org
Sat Sep 15 16:49:37 PDT 2012
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: tiger geocoder | Version: trunk
Keywords: |
Currently the geocoder puts in a 10 meter offset. Meaning
If you give it an address, it determines what side of the street the
address should be on and offsets it off the street center line by 10
meters.
Unfortunately there is no way to remove the offset or change it to
something bigger or smaller, without changing the function default on the
internal function:
interpolate_from_address
See
http://www.postgis.org/pipermail/postgis-users/2012-September/035265.html
So proposastion is to add another default arg at the geocode function to
allow this setting to be overriden.
Setting to 0 would result in no offset.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2000>
