[postgis-devel] Cannot get http://www.apache.org/dist/maven/binaries/maven-ant-tasks-2.1.3.jar
Sandro Santilli
strk at keybit.net
Mon Sep 17 04:43:42 PDT 2012
On Mon, Sep 17, 2012 at 05:03:18PM +0530, Sandeep Thakkar wrote:
> I have attached the patch which fixes the path in buid.xml of jdbc.
Committed to the 2.0 branch and to trunk.
But I removed the "eu" part from the domain name (why restricting?)
Test welcome.
Since you're at it, maybe you can also take care of the other 3
pending Java tickets ?
http://trac.osgeo.org/postgis/query?status=assigned&status=new&status=reopened&component=java&order=priority&col=id&col=summary&col=status&col=type&col=priority&col=milestone&col=component
--strk;
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
