[postgis-devel] [PostGIS] #2004: wrong path to topology on postgis 2.1.0 xWin
trac at osgeo.org
Mon Sep 17 15:24:25 PDT 2012
Reporter: aperi2007 | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: build/upgrade/install | Version: trunk
Keywords: |
installing the postgis2.1.0 64bit per pg 9.2.
I notice that in the makepostgisdb.bat file
the path to topology is wrong.
Actually it is:
"%PGBIN%\psql" -d "%THEDB%" -f
"share\contrib\postgis-%POSTGISVER%\topology\topology.sql"
"share\contrib\postgis-%POSTGISVER%\topology\topology_comments.sql"
Instead it should be:
"share\contrib\postgis-%POSTGISVER%\topology.sql"
"share\contrib\postgis-%POSTGISVER%\topology_comments.sql"
Regards,
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2004>
