[postgis-devel] [PostGIS] #1998: Crash of topogeo_AddPolygon() with "ERROR: query string argument of EXECUTE is null"
trac at osgeo.org
Tue Sep 18 03:10:11 PDT 2012
EXECUTE is null"
Reporter: wimned | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: topology | Version: trunk
Keywords: topogeo_AddPolygon |
Comment(by wimned):
Created a workaround: After call of ST_ModEdgeHeal() the first point of
geometry of the new edge is checked against the geometry of the start
node.
When not, points are shifted in the edge geometry until the first point
matches the start node. The edge is removed using ST_RemEdgeModFace(). The
fixed geometry is added using topogeo_AddLineString()
The code (probably could be made less clumsy...):
CREATE OR REPLACE FUNCTION cleanse_node(passed_node_id integer)
returns void AS
DECLARE edge_ids integer[];
DECLARE start_node_id integer;
DECLARE node_geom geometry;
DECLARE edge_geom geometry;
DECLARE edge_sz integer;
BEGIN
--raise notice 'check node %', passed_node_id;
select array_agg(abs(t.edge)) into edge_ids
from GetNodeEdges('wimpy', passed_node_id) as t(seq,edge);
if array_length(edge_ids,1) = 2 and edge_ids[1] != edge_ids[2]
then
raise notice 'remove node %', passed_node_id;
perform ST_ModEdgeHeal('wimpy', edge_ids[1], edge_ids[2]);
select e.start_node into start_node_id from
wimpy.edge_data as e where e.edge_id = edge_ids[1];
select e.geom into edge_geom from
select n.geom into node_geom from
wimpy.node as n where n.node_id = start_node_id;
if not ST_Equals(node_geom, ST_PointN(edge_geom,1))
then
raise notice 'edge % needs fixing at %', edge_ids[1],
ST_ASText(node_geom);
edge_geom = ST_RemovePoint(edge_geom, 0);
edge_sz = ST_NPoints(edge_geom);
for i in 1..edge_sz
loop
exit when ST_Equals(node_geom, ST_PointN(edge_geom,1));
edge_geom = ST_AddPoint(edge_geom, ST_PointN(edge_geom,1),
-1);
end loop;
edge_geom = ST_AddPoint(edge_geom, node_geom, -1);
perform ST_RemEdgeModFace('wimpy', edge_ids[1]);
perform topogeo_AddLineString('wimpy', edge_geom);
end if;
end if;
END
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1998#comment:8>
