[postgis-devel] [PostGIS] #2007: topogeo_addlinestring: behaviour depends on query order (error - geometry intersects edge)
trac at osgeo.org
Tue Sep 18 09:23:53 PDT 2012
intersects edge)
Reporter: amartin | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: topology | Version: 2.0.x
Keywords: linestring, order |
Comment(by strk):
The fact that query order affects result is not a bug, but a well known
behavior.
Incremental construction of the topology tries to keep the elements which
were inserted before as immutable as possible, while is more liberal about
modifying (snapping, for instance) the items inserted later.
The "geometry intersects edge", on the other hand, is a bug.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2007#comment:1>
