[postgis-devel] [PostGIS] #2007: topogeo_addlinestring: behaviour depends on query order (error - geometry intersects edge)
trac at osgeo.org
Tue Sep 18 10:42:38 PDT 2012
intersects edge)
Reporter: amartin | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: topology | Version: 2.0.x
Keywords: linestring, order |
Comment(by strk):
I take it back, it's not between the input, but between two vertices in
the first geometry (the one which gets successfully added).
The snap tolerance you're passing (0.01) is higher than this distance
between adjacent vertices of the first geometry, which makes a mess.
This is another case in which an analysis function telling you what's the
closest non-zero distance between any two vertices of a geometry could
help.
Also, you may want to ST_Simplify your input geometries by the tolerance
value, prior to pass to addLinestring.
Not sure if PostGIS should do this automatically.
Anyway for this case, one of the correctly computed set of edges to add
from the second geometry becomes invalid once snapped to existing nodes.
The snapping _moves_ one vertex to collapse onto another. It _may_ or may
not be improved by disallowing snapping to a vertex of the input geometry.
It is basically this:
MULTILINESTRING((493339.655027555 4364376.38759966,493340.350449389
4364380.30185901),(493375.776788431 4364392.72706278,493383.13466486
4364395.75384862),(493340.350449389 4364380.30185901,493340.351099381
4364380.30551897,493349.447316675 4364380.22546209,493357.127624414
4364380.58832002,493363.534047898 4364383.70829175,493369.531348115
4364387.81043901,493375.776788431 4364392.72706278))
Snapped to this:
MULTIPOINT(493340.350449389 4364380.30185901,493375.776788431
4364392.72706278)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2007#comment:3>
