[postgis-devel] [PostGIS] #2008: Italian documentation is not showing new revision number
PostGIS trac at osgeo.org
Thu Sep 20 04:02:06 PDT 2012
 Reporter:  robe           |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.1.0
Component:  documentation  |     Version:  trunk
 Keywords:                 |
Comment(by robe):
 It's part of the build script for the docs I copied from Hudson.
 Here is the snippet of the script that does it:
 cd doc
 mv postgis.xml postgis.xml.orig
 sed -e "s:</title>:</title><subtitle><subscript>SVN Revision
 (<emphasis>${POSTGIS_SVN_REVISION}</emphasis>)</subscript></subtitle>:"
 postgis.xml.orig > postgis.xml
 make pdf
 make -e chunked-html 2>&1 | tee -a doc-errors.log
 make -C po/it_IT/ local-html
 mv postgis.xml.orig postgis.xml
 I assumed that since the pos are using the postgis.xml they should pickup
 any revisions
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2008#comment:2>
