[postgis-devel] [PostGIS] #2010: Can't install trunk on 9.3 instance
trac at osgeo.org
Thu Sep 20 09:42:08 PDT 2012
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Comment(by robe):
Still same error. You think maybe our make clean is not cleaning
everything. They do use the same source folder, so what you are saying is
possible if there is something wrong with our cleanup logic.
I'm going to try next on my windows box to confirm I have the same issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2010#comment:3>
