[postgis-devel] [PostGIS] #2020: Regress windows 32 9.2 and 9.1 x64
trac at osgeo.org
Fri Sep 28 12:59:35 PDT 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
winnie is registering a regress failure. Have to investigate:
Running tests
loader/Point .............. ok
loader/PointM .............. ok
loader/PointZ .............. ok
loader/MultiPoint .............. ok
loader/MultiPointM .............. ok
loader/MultiPointZ .............. ok
loader/Arc .............. ok
loader/ArcM .............. ok
loader/ArcZ .............. ok
loader/Polygon .............. ok
loader/PolygonM .............. ok
loader/PolygonZ .............. ok
loader/TSTPolygon ......... ok
loader/TSIPolygon ......... ok
loader/TSTIPolygon ......... ok
loader/PointWithSchema ..... ok
loader/NoTransPoint ......... ok
loader/NotReallyMultiPoint ......... ok
loader/MultiToSinglePoint ......... ok
loader/ReprojectPts ........ ok
loader/ReprojectPtsGeog ........ ok
loader/Latin1 .... ok
binary .. ok
regress .. ok
regress_index .. ok
regress_index_nulls .. ok
lwgeom_regress .. failed (diff expected obtained:
/tmp/pgis_reg/test_27_diff)
regress_lrs .. ok
removepoint .. ok
setpoint .. ok
simplify .. ok
snaptogrid .. ok
summary .. ok
affine .. ok
empty .. ok
measures .. ok
legacy .. ok
long_xact .. ok
ctors .. ok
sql-mm-serialize .. ok
sql-mm-circularstring .. ok
sql-mm-compoundcurve .. ok
sql-mm-curvepoly .. ok
sql-mm-general .. ok
sql-mm-multicurve .. ok
sql-mm-multisurface .. ok
polyhedralsurface .. ok
polygonize .. ok
postgis_type_name .. ok
geography .. ok
out_geometry .. ok
out_geography .. ok
in_gml .. ok
in_kml .. ok
iscollection .. ok
regress_ogc .. ok
regress_ogc_cover .. ok
regress_ogc_prep .. ok
regress_bdpoly .. ok
regress_proj .. ok
regress_management .. ok
dump .. ok
dumppoints .. ok
wmsservers .. ok
wkt .. ok
wkb .. ok
tickets .. ok
typmod .. ok
remove_repeated_points .. ok
split .. ok
relate .. ok
bestsrid .. ok
concave_hull .. ok
hausdorff .. ok
regress_buffer_params .. ok
offsetcurve .. ok
relatematch .. ok
isvaliddetail .. ok
sharedpaths .. ok
snap .. ok
node .. ok
unaryunion .. ok
clean .. ok
relate_bnr .. ok
delaunaytriangles .. ok
in_geojson .. ok
uninstall .. ok (4061
Run tests: 87
Failed: 1
make[1]: *** [check] Error 1
make[1]: Leaving directory `/c/jenkins/postgis/branches/2.1/regress'
make: *** [check] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2020>
