[postgis-devel] [PostGIS] #2022: Debbie renqme postgis.xml probably needs a closer look
trac at osgeo.org
Fri Sep 28 20:15:59 PDT 2012
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: buildbots | Version: trunk
Keywords: |
Debbie failed a bit after Bborie committed some changes.
Fixed now. I had to delete the postgis.xml and postgis-out.xml from her
branches/2.1 workspace and rerun. I think it has something to do with the
step where I put in a sed call to copy over the old postgis.xml to
postgis.xml.orig etc. and then it injects the SVN number and then copies
back. Porbalby a synchronization issue there still somewhere with 2 jobs
fighting for same resource.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2022>
