[postgis-devel] AddRasterConstraints failing to create extents in raster_column view
ryagz
raghavendra at vizexperts.com
Fri Apr 19 10:09:47 PDT 2013
I ran the .sql file, it ran a sequence of sql queries and then gave some
errors and roll back like bellow:
psql:C:/Program Files
(x86)/PostgreSQL/9.1/share/contrib/postgis-2.0/rtpostgis_u
pgrade_20_minor.sql:3764: ERROR: function "st_union" already exists with
same a
rgument types
pgrade_20_minor.sql:3771: ERROR: current transaction is aborted, commands
ignor
ed until end of transaction block
pgrade_20_minor.sql:3780: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:3786: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:3868: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:3874: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:3880: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:3886: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:3892: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:3898: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:3922: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:3952: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:3968: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4006: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4012: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4028: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4071: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4084: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4100: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4142: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4155: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4171: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4218: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4224: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4240: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4274: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4280: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4301: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4327: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4333: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4349: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4385: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4391: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4407: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4412: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4461: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4467: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4483: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4488: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4541: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4547: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4563: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4568: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4621: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4627: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4761: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4771: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4846: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:4867: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5001: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5011: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5086: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5107: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5145: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5155: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5177: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5210: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5216: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5248: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5329: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5339: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5397: ERROR: current transaction is aborted, commands
ignor
pgrade_20_minor.sql:5406: ERROR: current transaction is aborted, commands
ignor
ROLLBACK
-Ryagz
View this message in context: http://postgis.17.x6.nabble.com/AddRasterConstraints-failing-to-create-extents-in-raster-column-view-tp5003029p5003059.html
Sent from the PostGIS - Dev mailing list archive at Nabble.com.
