[postgis-devel] AddRasterConstraints failing to create extents in raster_column view
ryagz
raghavendra at vizexperts.com
Fri Apr 19 11:49:49 PDT 2013
Usually I install posgis form the postgresql's stack builder. That is where i
got 2.0.1.
Today i also tried re installing postgresql and postgis, the stack builder
directly gave 2.0.3. I tried addRasterConstraints on the same table and I
am getting same error. May be i will try uploading to fresh table again and
see if this can be reproduced.
View this message in context: http://postgis.17.x6.nabble.com/AddRasterConstraints-failing-to-create-extents-in-raster-column-view-tp5003029p5003061.html
Sent from the PostGIS - Dev mailing list archive at Nabble.com.
