[postgis-devel] AddRasterConstraints failing to create extents in raster_column view
Bborie Park
dustymugs at gmail.com
Mon Apr 22 19:44:51 PDT 2013
Strange.
Can you provide the output of the following?
SELECT version() || ' ' || postgis_full_version();
If you're actually using 2.0.3, the NOTICE that you provided has
additional information. The source for
_add_raster_constraint_extent() confirms that.
http://trac.osgeo.org/postgis/browser/tags/2.0.3/raster/rt_pg/rtpostgis.sql.in.c
Can you confirm that you're using EnterpriseDB's instance of
PostgreSQL and PostGIS? I'm wondering if their instances are shipping
with out-of-date files...
You can always try the latest windows binaries available at:
http://postgis.net/windows_downloads
-bborie
On Mon, Apr 22, 2013 at 7:22 PM, ryagz <raghavendra at vizexperts.com> wrote:
> I ran this query from PGAdmins Query tool and the History found in that tool
> is like this:
> SELECT _add_raster_constraint_extent('tkp_raster_satellite', 'wb32_64_1',
> 'rast');
> NOTICE: Unable to get the extent of a sample raster
> Total query runtime: 1119183 ms.
> 1 row retrieved.
> View this message in context: http://postgis.17.x6.nabble.com/AddRasterConstraints-failing-to-create-extents-in-raster-column-view-tp5003029p5003086.html
> Sent from the PostGIS - Dev mailing list archive at Nabble.com.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
