[postgis-devel] Updates to address standardizer
maplabs at light42.com maplabs at light42.com
Fri Apr 26 10:18:10 PDT 2013
What is the significance of sew-refactor versus sew-refactor2
On Thu, 25 Apr 2013 21:11:22 -0400, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
Hi all,
> There have been a bunch of small updates to the pagc address
> standardizer today.
> * relaxed sanitizing lex, gaz and rules table names and allowed schemas
> * added "order by id" to the internal queries to select the records
> from these tables, because changes in order can potentially impact
> results.
> * cleanup some compile time warnings
> * added some missing error checks so we exit nicely
> So if you are tracking this, it would be good to pull the current
> copy (Rev: 357).
> If you have questions on how to use this or how it works, I'll be
> happy to answer them if I can.
> Thanks,
>    -Steve
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
